9 bolt help - rebuild
Old Feb 22, 2011 | 02:26 PM
Riss's Avatar
Car: Camaro RS
Engine: 305 TBI
Transmission: 700
Axle/Gears: Borg-Warner 9 bolt
Want to rebuild my 9bolt rear, currently it does not lock I tried to fix it by adding shims but it still does not lock, maybe I did not put enough shims or maybe I just did it wrong.
Anyway, I decided to buy the already rebuild diff from 9bolt.com and just replace my old one and maybe i'l try to fix mine later.
The question is: I am trying to fully prepare for the rebuld which I will do in about a month, since parts are not easy to get here, I want to know what other parts do I need to replace to build a strong axle.
Currently I have a rebuld carrier and a good strong aluminum diff cover. Does anyone know the part numbers for the axle shaft bearings and seals for the 9 bolt or a link where to get them? Also are there any other parts I may need to order for the rebuild which I did not account for?
Old Feb 22, 2011 | 05:14 PM
big gear head's Avatar
Re: 9 bolt help - rebuild
Get a good installation kit. This will have new differential and pinion bearings, differential and pinion shims, pinion nut and seal, crush spacer, gear marking compound and some other stuff that you will need. Get a GOOD kit, not something cheap. Yukon makes a good kit for the 9 bolt. I've used these many times.
Old Feb 22, 2011 | 08:29 PM
IAGTA's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
Ratech Mfg is a great source for 9 bolt parts (Only place I could find carrier shims available separately)
http://ratechmfg.com/
Also, Randy's Ring and Pinion offers a good choice of parts.
And of course, 9bolt.com.
As a novice to rear ends I've found the 9 bolt to be both simple and frustrating to work on - they come apart nicely but don't like to go back together very easily. I've been struggling to properly re-install my axles now for months (I know that makes me sound like I'm clueless and maybe I am) after upgrading my brakes.
Anyway good luck!
Old Feb 22, 2011 | 10:36 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Whats wrong with the axles?
Old Feb 23, 2011 | 12:43 AM
I try to avoid Ratech stuff. There are much better kits available. DTS, Dewco, Tom's Differentials and Yukon are the only kits that I use. I haven't found any others that are as good as these.
Old Feb 23, 2011 | 12:55 AM
Riss's Avatar
Car: Camaro RS
Engine: 305 TBI
Transmission: 700
Anyway good luck!
Thank you for the link!!! Looks like everything that I need is there.
Old Feb 23, 2011 | 12:56 AM
Riss's Avatar
Car: Camaro RS
Engine: 305 TBI
Transmission: 700
Where can I find those?
Old Feb 23, 2011 | 03:52 PM
IAGTA's Avatar
Why would you avoid Ratech? Price, quality, service or ? The bearings I received were name brand and the price was equivalent to others. I ordered carrier shims on Sunday and received them today (Tuesday).
Just curious.
Old Feb 23, 2011 | 07:54 PM
The Ratech differential shims are not as good as the others. They are harder to use and sometimes you can't get the thickness that you want because there isn't a good enough selection of shims in the kit. They also use generic nuts for the pinion and they use other cheap stuff in the kits. The kits that I listed have the best parts and shims in them.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
