strange feeling when driving
Old Feb 23, 2011 | 08:40 PM
19f0rmula88's Avatar
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
i have an 88 formy with a 5 speed. when i put it into 1st gear and drive the car makes this like jumpy pully feeling i cant explain it but it feels like the rear axle is rocking back and forth its more or less a jerking motion whats going on with this?
also my friend has a 94 formula hes selling his rear its a posi disc would this fit my bird? if it can be used. what all will i need from the parts store/summit to get this bad boy to go in
Old Feb 23, 2011 | 11:12 PM
Shroken's Avatar
Car: '85 Trans Am
Engine: 350 Crate Motor
Axle/Gears: 3.27 posi
Re: strange feeling when driving
I understand It should bolt right in. It will stick out an extra 2" each side but thats no biggie. I believe you just need to get the brake lines firgured out if I remember correctly. I've wanted to do the same thing with my TA.
As to whether or not it will fix your problem......does it do that with all gears or just 1st? And how's the clutch? old, new, who knows?
Infested
May 22, 2018 11:56 PM
maroe624
Apr 16, 2017 08:29 AM
red90IROCls1
Aug 25, 2015 06:56 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
