Will 4wd trans work?
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: Will 4wd trans work?
it should the only thing that makes it 4 wheel is the transfer case which is connected to the trans itself
If i am correct and if not can someone please let me know. I think the only difference is the tail cone needs to be changed to a 2wd could be wrong it might also need a 2wd output shaft
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
yeah im not too sure on that, i just know that the transfer case isnt part of the trans, its connected to it which makes your front wheels work also when put into gear. as for the input shafts it might need it seeing as a transfer case isnt connected with a yoke, wchih a driveshaft is
I found this, it might help
http://www.truckforum.org/forums/che...4x4-th350.html
Basic opposite of what you want to do
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
we were on the right track, sounds lke alot of work, and alot can go wrong if youve never rebuilt a tranny
