swapping rear gear questions...
Old Mar 2, 2011 | 01:19 AM
Dougie91's Avatar
Car: 1992 Firebird convertible
Engine: 5.0 tbi
Axle/Gears: stock, slow and steady 2.73's
I have the stock 2.73s and i wanna swap out for 3.73s, am i gonna get a significant difference in launch?
Old Mar 2, 2011 | 01:39 AM
Killerz187's Avatar
Car: '91 Camaro RS T-Top
Engine: 383 Stroker
Transmission: Bulldog 700r-4
Re: swapping rear gear questions...
You'll probably feel a difference, but that 305 (if that is what you have) still isn't a big tire burner.
Old Mar 2, 2011 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Most members wouldn't recommend 3.73's with a 700R4.
JamesC
Old Mar 2, 2011 | 05:58 PM
Dougie91's Avatar
Engine: 5.0 tbi
tranny cant handle it? what gear is reccomended
Old Mar 2, 2011 | 06:27 PM
JamesC's Avatar
3.73's are apparently out of the power band. 3.42's seem to be what's recommended. A search will provide more info.
JamesC
Old Mar 2, 2011 | 06:37 PM
3.73s behind a trans with a 3.xx 1st gear and a motor that won't rev, will LAUNCH you to about 5 mph; and then you'll feel sort of stuck.
Ever drive one of those cars that could just SMOKE the tires sitting still, but can't pass a semi on the freeway at 55 mph unless it's a long downhill grade? That's kind of what that combo will act like.
Just too much gear for the rest of the car. It will force the motor to always be in a range of RPM where it has absolutel no power whatsoever.
Now, do something about the restrictive exhaust, the cam that you could hide the lumps on with Clearasil, and the heads that .... ,,,, ..... ummmm yeah .... , and it could be ALOT more fun.
Old Mar 13, 2011 | 03:06 PM
Dougie91's Avatar
Engine: 5.0 tbi
Well I have a 305 and I was just looking for a easy way to run a lil quicker
Old Mar 15, 2011 | 04:31 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Get 3,23 gears, 3.73 with an automatic V8 combo is a hell no. you will rev to 3500 rpms a 60mph, you can expect 8-10 mpg. 3.73s are made for a t56 imo.
Old Mar 15, 2011 | 05:43 PM
Dougie91's Avatar
Engine: 5.0 tbi
my mpg gonna suck with 3.23s?
Old Mar 15, 2011 | 06:22 PM
89rs454's Avatar
Car: 1989 SS
With gas prices the way they are any gear ratio gonna suck.
Old Mar 15, 2011 | 10:38 PM
Dougie91's Avatar
Engine: 5.0 tbi
lol good logic, but am i gonna have a drastic drop?
Old Mar 16, 2011 | 12:24 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I would say do all the "basic" up grades,Intake,full exhaust, etc. and go 3.42s and the Eaton Posi. Thats what I did and could not be happier. Pulls nice and hard from a launch and is fine on the free way with OD.
Old Mar 16, 2011 | 12:55 AM
iroc-z_23's Avatar
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
i say 3.73s and widen your rpm band. you will tell a difference.
i have 3.73s in my 350 with 750 carb and as long as its tuned right you can get good gas mileage with your car. fuel injection can be a little over-rated. i get better gas mileage with my carburetor than when i had tpi
Old Mar 16, 2011 | 12:34 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
what trans are you running? I dont turn near that amount.
I have 3.73s and love them in my car. I wouldnt go any lower though.
Old Mar 16, 2011 | 02:27 PM
89rs454's Avatar
Car: 1989 SS
It was a turbo350 out of an old truck .
Old Mar 16, 2011 | 05:20 PM
3rdgenmaro's Avatar
Car: 88 IROC
so why did you tell somebody with a 700r4, that they would be turning 3500 rpms at 60 with 3.73s?
Keep apples with apples
Old Mar 16, 2011 | 08:02 PM
iroc-z_23's Avatar
Engine: 355 SBC
my car never turns 3500 unless I'm doing about 75-80
Old Mar 16, 2011 | 09:26 PM
89rs454's Avatar
Car: 1989 SS
He never said he had a 700r4? Besides that IMO 3.73s is to much for automatic. Cheers.
Old Mar 16, 2011 | 10:32 PM
Dougie91's Avatar
Engine: 5.0 tbi
my tranny is stock to the lo3
Old Mar 16, 2011 | 11:08 PM
89rs454's Avatar
Car: 1989 SS
Then it's a 700r4, Sorry i was basing my assumption on a Turbo350 transmission and forgot overdrive on the 700r4, which i still think 3.73 gears is overkill for a stock auto lo3.
Old Mar 17, 2011 | 10:22 PM
JordanRAdams's Avatar
Car: 89 IROC-Z
Engine: 305 TPI, bored .30 over, cammed
Axle/Gears: 3.45
It seems like gears could be hit or miss without having it on a dyno. I just bought an 89 Iroc that's pretty heavily modded in the engine, but nothing done to the gears or trans. It's a 5-speed tho, so with the engine mods would it be logical to go to a 3.73? I guess I've already answered my own question though: put it on the dyno.
Old Mar 18, 2011 | 01:24 AM
iroc-z_23's Avatar
Engine: 355 SBC
So your gonna buy like 10 sets of gears, remove and install them, and try them all out on the dyno just to see which one performs better? HAHA
Base your gear ratio on how you drive. If your a street strip car, hands down 3.73 is the best gear combo. If you want a little more @$$ than stock I'd go 3.42s or something. If I wasn't running nitrous I'd have 4.10s. I just want to go fast. And looking for lower e.t
p.s a lot of 5 speeds came out with 3.73s stock you will probably want to check on that
Old Mar 18, 2011 | 05:02 AM
Car: 89 IROC-Z
Axle/Gears: 3.45
Haha, no, I didn't mean keep putting different ones in, I just meant find out how much power it's got so you could pick the right ones. Maybe I'm not understanding exactly how a dyno works though, it should put out the same horsepower no matter how it's geared is what I'm thinking. =)
Like you, I just want to go fast. The engine has like every power mod you can do, and I would like to be able to take advantage of that. ( I bought it that way)
Old Mar 18, 2011 | 07:20 AM
THe dyno doesn't care what the gearing is; it relates power, to engine RPM. Pays no attention to wheel speed, as far as its power calculations are concerned.
It will tell you, in what RPM range the engine makes the best power. You selct gears, to make the engine run in some given RPM range. THerefore the dyno tells you EXACTLY what you need to know.
Besides, it's always fun to hear your car wind out at full throttle.
Old Mar 18, 2011 | 07:53 AM
Car: 89 IROC-Z
Axle/Gears: 3.45
That's what I was wondering. Thanks!
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
