4:10s in a driver bad??? or
Old Mar 7, 2011 | 12:04 AM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
i got 4:10s on my truck but its got 35" tires whats it like in a camaro?
My friend has a iroc axle, disc, with a new eaton posi and 4:10s. I was thinking about getting it to replace the open drum axle. If i dont like the 4:10s cant i change out the ring gear to a 3:42 or 3:73?
Help appreciated thanks.
Old Mar 7, 2011 | 12:41 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: 4:10s in a driver bad??? or
You have a 700R4 according to you, so I don't see why you'de want to drop down a notch. They're fine.
Old Mar 7, 2011 | 12:59 AM
Car: 84 Trans Am
what kinda rpm will i run with overdrive still wanna pull off a 100 and so, with out going boom lol
Old Mar 7, 2011 | 10:24 AM
bracket rs's Avatar
mine turns 2600 rpm with 275/60's at around 62mph, in the 1/4 mile i'am at 4500 rpm
in 3rd gear at 85 mph, i leave it in 3rd in the 1/4 mile so i can't give you a 4th gear rpm but should be ok at a 100 in 4th
Old Mar 7, 2011 | 10:46 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
that's alot of gear for a 305 daily driver. whether you can swap to a 3:73 or 3:42 depends on the carrier iirc, I just read a post the other day that stated that 3:42 are about the best ratio for a dd with a 305 and 700r4 .
Old Mar 7, 2011 | 11:28 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
www.f-body.org/gears
Old Mar 7, 2011 | 11:11 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
3.42 stock 26 inch tires 700r4 at 70 is about 2450 rpms
the same with 4.10's will probably be around 2900 rpms. which for a highway driver is too much in my eyes.
Old Mar 8, 2011 | 10:17 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
With $4 a gallon gas easily on the way, I wouldn't want more than 3.42's!
Too bad there's not a way of flipping a lever and switching from 2.73's to whatever. Could save gas on the highway, but have gears for a bit of fun when desired.
Old Mar 8, 2011 | 11:18 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Tires size makes a difference as it effectivly changes your rear gear ratio compared to stock config.
Why trucks with hugh tires have such low gears.
have a 2:73 rear and big tires like that and it won't go anywhere.
sames goes the other way, got granny gears and run tires smaller then stock raises it. [not done often though I do. stock on my Buick is 225/70, I run 225/60, doesn't sound like much but much better take off, though the 70s had more pep above 100, but I don't do high speed runs often.]
Glowsock
Jul 24, 2025 03:15 PM
redmaroz
Apr 25, 2017 07:14 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Bryan F
Aug 18, 2015 02:28 PM
