Greasing bearings before install
Old Mar 8, 2011 | 11:17 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Quick question; Do you need to grease the bearings on either side of the carrier and on the inside of the pinion shaft before installing everything? I just ask because the housing will be full of gear oil. Will the grease contaminate the gear oil?
Old Mar 8, 2011 | 05:45 PM
Keoman's Avatar
Re: Greasing bearings before install
anybody?
It can't be that big of a secret! I'll make sure i was clear enough.
Before installing everything, do the bearings need to be greased or will the gear oil do the job?
Old Mar 12, 2011 | 07:15 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Originally Posted by Keoman
anybody?
gear oil like you said will be fine. lube the seal with gear lube, liquid pipe sealant on the splines of the yoke and you will be good to go
Old Mar 12, 2011 | 07:46 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
no grease,just gear oil.
anesthes
Mar 10, 2016 10:35 PM
dyeager535
Aug 28, 2015 08:10 AM
red90IROCls1
Aug 25, 2015 06:56 AM
rsrmoore
Aug 7, 2015 08:44 PM
