454 t56 swap!!
Old Mar 11, 2011 | 11:06 AM
Jake88maro's Avatar
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
454 t56 swap!!
okay so i've finally got my 454 t5 up and runnin! (btw i would post pics but my computer says their inncorrect or somethin!) but by now i have realized that t5 isnt gonna last much longer. it is a wc t5 but still, no good. well i'm plannin on retrofitting a t56 with the t5 bellhousing. but i'd like to use a viper t56. but how would i do tha spline wise? like clutch plate and drive shaft wise?
Old Mar 11, 2011 | 01:16 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: 454 t56 swap!!
Throw this in google as a start:
site:www.thirdgen.org T56 BBC
A true viper T56 will need machinework done on the input shaft. I can get more specific if needed.
Old Mar 11, 2011 | 10:06 PM
Jake88maro's Avatar
Re: 454 t56 swap!!
yeah a scatterproof will be necessary for sure. could you elaborate some more about the machining aspect? and what clutch you would reccomend?
Old Mar 11, 2011 | 10:30 PM
Jake88maro's Avatar
Re: 454 t56 swap!!
yeah i would appreciate the info on machining the viper t56. and thay are rated for 800 ft lbs right?
Old Mar 12, 2011 | 07:55 AM
85MikeTPI's Avatar
Re: 454 t56 swap!!
You might have to shorten the viper input shaft slightly and machine the pilot down. (Last one I did was shortened to LS1-T56 length, your application might not need shortening) Or You could machine down a Mopar pilot bearing to fit your BBC crank and use the viper t56 as is. It is also 26 spline, so GM clutches/disc will work.
The stock viper T56 is rated at 550lb-ft, over the 450lb-ft that F-body T56s are. The 700-800lb-ft ratings are advertised by rebuilders after adding all the upgrades to a stock T56.
You can buy a spicer 30spline 1350 yoke and fit it to you driveshaft, but the drive shaft would need shortened several inches.
Old Mar 13, 2011 | 09:53 AM
Jake88maro's Avatar
Re: 454 t56 swap!!
okay i think i understand what you sating, but let me get this straight the only thing that needs shortened is the pilot bearing part of the input shaft? or you could grind the pilot bearing down you said?
Old Mar 13, 2011 | 10:11 AM
85MikeTPI's Avatar
Re: 454 t56 swap!!
If you use the adapter plate, I'm 99% sure you won't need to shorten it. The viper pilot is 0.750" in diameter, whereas the GM pilots are 0.590" so you'll need to machine the pilot diameter, or get a Mopar pilot bushing and fit it into your BBC crank.
I took some pics several years ago when I had both an Aftermarket-T56 and Viper-T56 in the shop, but I wasn't thinking far enough ahead to take precise measurements:
http://www.eecis.udel.edu/~davis/z28...4_ViperT56_web
The plate would start about 3/8" out from where I started to measure the length of the viper input, and the plate is 1/2" thick. That would put the tip of the viper out 7-1/4" from the face of the plate. The aftermarket T56 input tip is out 7" from the face of the plate.
Old Mar 13, 2011 | 11:53 AM
Jake88maro's Avatar
Re: 454 t56 swap!!
oh wow i see now. okay sweet a really appreciate all of this help! and you would recommend the upgraded t5 bellhousing? who makes a strong one?
Old Mar 14, 2011 | 10:58 AM
85MikeTPI's Avatar
Re: 454 t56 swap!!
I like Quicktime. The lakewood is ok also, but you hear all kinds of stories of alignment problems.. You should check any of them for alignment though..
Old Mar 14, 2011 | 11:21 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: 454 t56 swap!!
If you were to use a LT1 T56 McCleod makes a nice scattershield you can order through Summit. When they say direct bolt in its just that, no indexing nothing. More room than the stock bellhousing, love mine. Just a thought.
Quicktime also, much ligher I hear. Mines 38 lbs includes a block protector plate so if something happens you dont take that out. Options..
how much power are you putting out?
Protecting those feet legs and god knows what else is priceless only 1 shot at that.
Some say if youre using a billet FW youll be Ok but dont trust that, the clutch can break too.
Old Mar 14, 2011 | 06:01 PM
Jake88maro's Avatar
Re: 454 t56 swap!!
its got a stock rebuilt bottom end with a mild cam and stock heads. so maybe 280 hp about 380 ft lbs? not really sure. its a 1979 1 ton truck motor
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 26, 2015 07:54 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
