700R4 to T-5 which wire isnt used?
Old Mar 27, 2011 | 01:26 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
Here is a link to my other thread. Im not getting very many answers in electronic so i figured id try transmissons. thanks
https://www.thirdgen.org/forums/elec...ml#post4868652
Auto plug
Manual plug
Old Mar 27, 2011 | 03:55 PM
Car: 91 RS T-top
Re: 700R4 to T-5 which wire isnt used?
Also from the 700r4 do I use any of these? I know 2 go to the radiator but I don't see a place on the T5 to put any of these. Thanks
Old Mar 27, 2011 | 05:55 PM
fordspanker's Avatar
Car: 92 Camaro Vert, 91 RS
Engine: 355ci
Transmission: TKO 500
Axle/Gears: 10 Bolt 3.73 posi
The 2 lines are the transmission cooler lines, you do not use them on a manuel trans, the connector is for the torque converter lock up, you will not use that either, I think the t-5 connector is for your reverse switch.
Old Mar 27, 2011 | 05:56 PM
Car: 91 RS T-top
Thanks for the help
Old Mar 27, 2011 | 09:54 PM
znate's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
the two wire connector is for the speed sensor and the four wire connector is for the auto tranny lock up convertor.
Old Mar 28, 2011 | 10:21 AM
Car: 91 RS T-top
No the top is auto the bottom manual. The are from different car's.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
g.l.mos
Aug 22, 2015 12:02 AM
