Trans swap/ pedal swap
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
Re: Trans swap/ pedal swap
1 on your clutch and on brake pedal with a vacuum hose on it are 2 sensors for cruise control and the other switch is for brake lights and torque converter lockup
There is one brake light switch (turns the brake lights off then the pedal is not pressed), one cruise control safety switch (disengages the cruise both by breaking its vacuum system and its electrical power when the clutch is pushed), and one clutch safety starting switch (won't let the car start unless the clutch is to the floor)
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
there are very different switches on different years. For example, the clutch switch (cruise i think) were changed from vaccum to electric in 87. I can send you some pics of the pedal assemblies for differnt years. which year harness do you have?
1992 Trans Am
May 10, 2023 07:19 PM
