Looking to know basics about auto transmission
Old Apr 6, 2011 | 09:14 PM
Reddeath210's Avatar
I have a stock 4 speed auto trans in my 85 firebird.i was looking to see how a 5 speed auto would cost but I have no idea wat to even start to look for in a transmission. I have no Idea how to take on out or install one. This is all new to me so any help or guides are really appreicated thanks
Old Apr 6, 2011 | 10:39 PM
Gonzales7's Avatar
Car: 1990 Camaro RS
Engine: 5.7 350
Transmission: Built 700R4 with 2700 stall
Axle/Gears: Moser axles with 4.10s POSI
Re: Looking to know basics about auto transmission
On http://www.hawksthirdgenparts.com/ they sell a conversion kit to swap in a t-5 in your car and its around 1,500 dollars if that helps
Old Apr 8, 2011 | 03:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There is no compatible 5 speed automatic transmission available that I know of. Or 6 speed automatic. Or anything other than what you have.
Do you want an automatic, or do you want a manual transmission?
If you want an automatic, you have it - that's it, that's all there is - there's nothing else available, and no need since there's nothing wrong with a good 700R4 automatic. Even the automatics from the 4th gen cars are not compatible - since they were computer controled and you don't have the computer (which is expensive).
If you want a manual tranny, there's alot of options - cheapest being a T5 5 speed from same years camaros/firebirds (but they are weak) about $800 maybe with all needed parts. Next best is a T-56 from a 1993 - 2002 camaro/firebird - maybe $2000 max with all needed parts. Otherwise, there's many other brands of manual trannies you can buy, starting at about $2000 up to more than you have.
To swap in a manual transmission you need the pedals, clutch assembly, etc. as well as the transmission. You have to cut out the holes in the firewall for the pedals and such.
Old Apr 8, 2011 | 06:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
BMW is coming out with an 8 speed auto. Nothing like keeping the engine at an exact rpm as your speed changes. The engine must have a real narrow powerband.
My Ford F350 has a 5 speed auto.
Old Apr 8, 2011 | 08:51 PM
Car: 1992 RS
Engine: Carbed 350
Off topic - but last weekend I saw a F650 at a car show - talk about a case of "compensation for lacking in other areas"! That was a beast! At $4.00 a gallon for the deisel fuel, it would take 3 times the monthly payment in fuel expense to drive it 20 miles to work everyday! Glad it ain't mine!
AussiePr0nCar
Mar 6, 2020 04:04 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
LittleFranks
Sep 17, 2015 12:22 PM
theshackle
Aug 23, 2015 03:49 PM
ezobens
Aug 19, 2015 10:29 PM
