Tko 600 with quick time bellhousing help
Old Mar 28, 2011 | 01:03 PM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
Ok so i am in the process of installing a Liberty Geared Tko 600 into my 85 Ta. They sent me a Quick time bell housing that does not have provision for an external slave pt number rm-6021. I have called liberty, qucktime, and D&d trans with no real info. Only ifs and a mabe. I got a part number from Quicktime which is a rm-6018 that has provision for the external slave but it is clocked at 23 deg. whats the fix???? would appreciate any answers. Thanks.
Old Mar 28, 2011 | 08:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tko 600 with quick time bellhousing help
the angle should be more like 18degrees i think. thats how the stock t5 is mounted. FortesPartsconnection sells a adapter plate to mount the TKO straight up to a stock style bell with the angled pattern, but i believe it also requires the longer input shaft that he offers.
you could use a hydraulic TO bearing setup i suppose
Old Mar 28, 2011 | 09:23 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If the 600 is not canted like a T5, you don't want the rm-6018.
Any reason the Lakewood 15020 won't work?
Old Mar 29, 2011 | 12:04 AM
Car: 85 Trans Am
Engine: 383 ci
I will call lakewood on that part number tomorrow. I spoke with mike at Fortes and he is going to put together an external mount bracket/slave set up tomorrow morning. He really seems to know his stuff.
Old Mar 29, 2011 | 06:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yeah, Fortes is a FANTASTIC company/people, highly reccomended
Old Mar 30, 2011 | 08:38 AM
Car: 85 Trans Am
Engine: 383 ci
MIke is a wild guy. Funny as all hell. Looks like the 6021 qt bellhousing is not going to work at all. the starter hole is way off on the backing plate as well as the housing it self. I am calling lakewood today. Their bellhousing looks like money.
Old Mar 30, 2011 | 07:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im using lakewoods, no issues
Old Mar 31, 2011 | 12:14 AM
Car: 85 Trans Am
Engine: 383 ci
sweet that is the answer i was looking for.. It should be friday.
Old Apr 5, 2011 | 08:51 AM
Car: 85 Trans Am
Engine: 383 ci
what trans mount is everybody using with the lakewood? The one spohn recomends is not offset so it ends up being 3/8 off...
Old Apr 5, 2011 | 08:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
not sure about the offset thing?
trans mount or crossmember?
im using a prothane poly mount, with a UMI 700r4/t5 crossmember with 3/8" aluminum spacers packing it down off the subframe.
Old Apr 6, 2011 | 04:27 PM
Car: 85 Trans Am
Engine: 383 ci
Its the spohn crossmember for their adjustable torque arm. It is double wall so i drilled it out and bolted it from the inside.
Old Apr 8, 2011 | 08:50 AM
Car: 85 Trans Am
Engine: 383 ci
Ok so the trans is in and the car is off the lift. it looks like i am going to have to get a new shifter arm as the one that came with the shifter is now in the upper right hand corner of the shift hole. I have searched for pics with no luck. has any one done one on a pro 50 shifter. also what shift boot are the using?
Old Apr 8, 2011 | 07:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im using a steeda tri-ax, but you have to extend the handle about 1".
great shifter
Old Apr 8, 2011 | 11:54 PM
Car: 85 Trans Am
Engine: 383 ci
any pics?
Infested
May 22, 2018 11:56 PM
jharrison5
Aug 19, 2015 05:53 PM
86IROC112
Aug 17, 2015 02:00 PM
383backinblack
Aug 15, 2015 06:36 PM
