transmission noise
transmission noise
I have a 1989 camaro RS 305 5.0L with caburator and just changed out the water pump and radiator. Now heres the problem I notice with i engage the transmission from park to revers its make a clucthing noise and while in revers the engine will shut off it also make a noise engaging in drive as well but dosent shut off.
The carburator sounds like it is idle to high when engine starts an warms up RPM gage reads around 15 RMP.
I dont know were to start I only had the car for three months and I hope the transmission is not failing me now Help.
AL1989
AL1989
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: transmission noise
Did you swap to a carb, or are you calling the TBI unit a carb?
What's the radiator and water pump have to do with anything transmission related?
What is a "clutching" noise - never heard of that before. Do you mean it grinds? Or does it "clunk" into gear?
What is 15 RMP? Do you mean 1500 rpms?
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
