Please help!! 1987 iroc-z tranny
Old Apr 11, 2011 | 07:03 PM
browar87iroc's Avatar
Alright so just turned 16 and came across this little camaro. Need to figure out how hard it will be to weld the tranny to the frame.
http://www.ksl.com/index.php?sid=0&n...iew&ad=4181096
Old Apr 11, 2011 | 07:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Please help!! 1987 iroc-z tranny
You cannot weld the tranny to the frame! What is the issue exactly?
Old Apr 11, 2011 | 07:32 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
Ad says "weld the transmission brace to the frame" which I'm guessing means they stripped out the boltholes for the transmission crossmember. If that's the case, then welding the crossmember in will mean having to cut the welds if you ever need to remove the trans for any reason. Probably not a good idea.
Try to find a good mechanic to go with you to look at the car and see exactly how bad the damage is, so that you can get a better idea what it'll cost to fix before you buy the car.
Old Apr 11, 2011 | 08:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i've seen some of the crossmembers rot right off the frame.
its probably 170k miles, not 70k.
the car has the potential of being a disaster, keep looking
Old Apr 11, 2011 | 08:22 PM
Car: 1992 RS
Engine: Carbed 350
Yeah - if you haven't bought it yet, keep walking. It's too much work and not a good enough deal. I buy running 3rd gens all the time for under 1000 that have no problems.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
David Frans
Oct 31, 2015 08:12 PM
88CamZ
Oct 8, 2015 10:29 AM
bjpotter
Oct 4, 2015 07:48 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
