Fully seated stall converter?
Old Apr 11, 2011 | 08:41 PM
George90GTA's Avatar
Car: 1990 GTA
Engine: 355
I just put a new one in my 700R4. I heard 2 clicks as I pushed and turned it in. I measured it to the face of the bell housing. It measures 1 inch exactly. Is that enough??? The flywheel measures 7/8 inch from the block to face. Thanks.
Old Apr 11, 2011 | 09:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Fully seated stall converter?
It's possible one of those clicks was a double click. The converter should be almost right up to the pump. The only way you'll know if it's in all the way is to install the tranny. If the bellhousing bolts are done up and you can spin the converter than it's in far enough.
Old Apr 11, 2011 | 09:17 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
But do not draw the motor and trans together with the bolts. I did this and broke the tabs off the oil pump in the trans on my brand new, never driven on Hughes TH350. Had to replace the pump before I ever even used the trans.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
suzuki949
Aug 28, 2015 08:07 AM
Jake_92RS
Aug 17, 2015 09:42 AM
