sparks jumping from tranny dipstick
Old Mar 9, 2011 | 05:19 PM
RoosterC's Avatar
Car: 1988 Maui Blue Camaro
Engine: Pea Shooter
Happens when I get to about 1/8 throttle and I can hear an audible clicking sound, quite frequent until I get off the gas or go past it. The sparks will also jump if I remove the dipstick and make contact with the tube while I'm putting it back in, not too sure what's going on here...
Old Mar 9, 2011 | 06:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: sparks jumping from tranny dipstick
Sounds like a bad plug wire that's 'leaking' and arcing on dipstick - presumably #8 plug wire.
Old Mar 11, 2011 | 03:34 PM
RoosterC's Avatar
Engine: Pea Shooter
I'll check that out, thanks for the tip
Old Mar 12, 2011 | 01:34 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Mine did that once.it was either bad plug wire or coil.Cant remember.May have been both.
Old Mar 16, 2011 | 12:07 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Check your ground straps to make sure they are all there and in good shape.
I had this issue on a car with bad grounds...so the tranny dipstick happened to be completing the circuit
Old Apr 11, 2011 | 09:24 PM
RoosterC's Avatar
Engine: Pea Shooter
I will certainly give that a shot!
codeysabatini
Nov 10, 2015 04:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
