T-5 to T-56
Old Apr 18, 2011 | 02:03 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
T-5 to T-56
Ok I swapped from my T-5 to an LT-1 T-56 everything is in the car working flawlessly wish exception of the speedometer..
I've searched all the threads and couldn't find a definitive answer for my question so here goes..
How do I get my speedomoeter to work properly? I wired in the vss from the trans but it appears to send a different signal than the factory unit seeing as how my speedo pegs as soon as I start rolling..
I imagine I need some sort of conversion box like that dakota digital one or something correct? or is there a VSS I can get that will fit the transmission and run my speedo like normal?
Any help is appreciated...
AL
Old Apr 18, 2011 | 06:32 PM
Re: T-5 to T-56
Yes the Dakota box should work in your case.... right now I'm guessing your speedo pegs the instant the car starts moving.... that would be because the T-56 VSS puts out about 17 pulses per rev or some such, but your car is expecting 4. So it thinks you're going at warp speed. The Dakota box acts as a divider.
Here's what you've got.
You need to electronically divide the # of pulses down quite a bit to get to 4 per rev, as you can see.
Old Apr 18, 2011 | 07:46 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
Re: T-5 to T-56
I wonder how well it'd work to just cut all but 4 of the teeth off the reluctor.....
I know the spacing would be slightly uneven, but AFAIK the $8D code doesn't check the speed or timing of the pulses, it just counts them as they come I'd think $6E (what your '89 runs) would work the same way. Trimming 13 teeth off with a die grinder might be the cheapest and easiest way to make this work. If my IROC still had a factory cluster I'd try it and see for myself.
And yes, the 4th gen T56 reluctor has 17 teeth. So 17 pulses per driveshaft rev.
Old Apr 18, 2011 | 10:07 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-5 to T-56
You'll notice there's no aftermarket 4 tooth reluctor ring. That is because it's not 4 pulses per revolution in anything.
Early Third-gen VSS was driven by speedo gears or within the speedo and is 2 pulse per speedo cable revolution (2002 square-wave pulses / mile.)
Then, the 90-92 cars all had VSS driven by speedo gearrs at the trans. and were 4 pulses per "speedo cable revolution" (4004 sine-wave pulses / mile.)
Some early 1993 F-body T56s had an 11 tooth reluctor. Later ones were 17 tooth. 1994-up Automatics got a 40 tooth reluctor.
Those are 11 / 17 / 40 pulse per driveshaft / output revolution. Number of tire rotations per mile * gear ratio * 11 (or 17 or 40) = the pulse per mile for comparison purposes.
Old Apr 19, 2011 | 10:03 AM
Car: 89 Formula
Re: T-5 to T-56
Thats what I thought thanks guys
Old Apr 19, 2011 | 06:59 PM
Jaxom's Avatar
Car: '89 IROC-Z
Re: T-5 to T-56
Yar. 4 pulses per driven gear revolution, not per driveshaft revolution. My mistake. It's been a LONG time since I worked with the factory speedo setup.
PurelyPMD
May 5, 2016 04:57 PM
tonys91rs
Oct 10, 2015 03:31 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
