700R4 Question
Old Apr 19, 2011 | 07:09 PM
jwoodworth90's Avatar
700R4 Question
350 TPI set up right now. Keep running into issues with the tpi/computer so i am going carb for now. Question do i have to keep the computer to control the tranny?
Old Apr 19, 2011 | 07:47 PM
Re: 700R4 Question
Ok after doing some searching i believe it will work all i need is a way to control TCC.... i plan on using this kit http://www.summitracing.com/parts/TCI-376600/
Old Apr 19, 2011 | 08:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700R4 Question
Yep - you need that or something similar.
With the TCI kit you have shown - just be very careful with the dimpy little vacuum switch they give you - it's a piece of crapola and breaks very easily, and there is no replacement for it (other than paying TCI for an entire new kit).
Mine broke when I ent to put the vacuum line on it - obviously a factory defect - but they wouldn't work with me on a return or switch replacement since I'd already installed everything else (which is what you do according to THEIR directions). Needless to say I was NOT HAPPY, and thus I personally refuse to buy anything TCI again due to their lack of customer service.
I just use their manual switch provision and control mine with a switch.
But it's as good as any other brand. No one makes anything that they can be proud of anymore!
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
