transmission intermittent
Old Apr 29, 2011 | 12:48 PM
csimpson1's Avatar
Car: 1984 Black Trans Am
Engine: 350 bored .030
Axle/Gears: Stock. Wanting up grade
Works great and powerful if I put it in gear right after I start it. If I do it that way both reverse works and drive. But if I remove it from one of the two. It WILL NOT go back into gear. Also, if I wait even 10th seconds before I put it in gear, it won't go. Tranny fluid is due for filter and fluid change. But sometimes, if I put it in year quickly and go, after I drive a bit, timing has always been different, it will "fall" out of gear. And then it won't even use first or reverse until I shut it off, restart and quickly shift. Transmission is 700r4 and was recently installed. I read there are vacuum lines? wiring Connector is in and works. I'm lost. Why it would engage now and not later. When shifting right, it shifts smooth and good. Thanks in advance guys.
350 in a 84 trans am. 700r4 tranny. Neither of the two came with this car. stock everything else.
Old Aug 16, 2011 | 08:19 AM
jameecrockettRS's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI (5.0L)
Transmission: 4 speed automatic
Re: transmission intermittent
Replace the clutch kit.
Old Aug 16, 2011 | 08:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There are no vacuum lines to a 700R4 tranny.
Veaceonee
Sep 29, 2016 08:15 PM
Grant2k
Apr 4, 2016 08:21 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TrevinE
Sep 14, 2015 03:20 PM
scottmoyer
Sep 7, 2015 07:06 PM
