Th200-C cable problem
Old May 4, 2011 | 10:43 PM
82crossfire305's Avatar
Car: 1982 Trans Am
Engine: LU5 CFI
Transmission: TH-200C
the transmission it self works fine, the other day i was driving and stopped at some appartments but i had to move so i reversed the car into a spot. the car stalled out on me happened five other times. started it back up i lost every gear except first and is stuck there. i move the shifter and the cable moves aswell, so the problem is internal. i have a book on the car unsure of when ill be getting it back left it at a friends house, so i wont be able to consult the book. i called up my uncle and he explained to me there is some sort of device i dont want to say the wrong thing, but the device keeps the cable attatched to it and he says it sounds like that would be the problem, i am unable to do any heavy work on vehicals in the appartments. so unless i know what it is or a general idea i wont be able to drop the pan to look at the device. if anyone could help or give advice i would apritiate it considering tight on funds and going to a garage where i hardly see 200C tranys might be expencive, with the guts of a 2004R or even a 700R4 work with my trans, im not looking to keep the tranny for a more than a year or two at the most so if anything will work ill take it. thank you
fyi sorry for the miss spelled words
Old May 5, 2011 | 01:42 AM
the_am_man's Avatar
Car: 82' T/A
Engine: LG4
Transmission: THM200c
Re: Th200-C cable problem
I would start with checking the fluid level. And to do that the car must be at operating temperature and running in park. They act awfully strange when low on fluid
Old May 5, 2011 | 06:21 AM
Car: 1982 Trans Am
Engine: LU5 CFI
ok thank you ill do that today when i get home from school and post
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
