Rear Axle Swap
Old May 12, 2011 | 08:33 PM
CalimaroRS's Avatar
Car: 91 Camaro RS
Engine: 305ci
Transmission: M5
Rear Axle Swap
hey everybody quick question.
i was on hawks third gen parts and i was looking at the third gen rear axle n they have posi rear disc for 82-88 and the have rear disc 1le for 90-92. i was wondering if the 82-88 one will work on my 91 camaro without any problem?
thanks for all the help n info
Old May 12, 2011 | 08:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Axle Swap
Both fit. The 82-88 is far less desirable because of the Delco-Moraine calipers, which are prone to failure--and, of course, the 10.5" rotors. Furthermore, the appropriate combination valve for that set-up won't fit your 91. There may also be parking brake cable issues if the 91 doesn't have the tunnel-mounted adjustment piece. Is this rear a 9- or 10-bolt?
The so-called 1LE rear is far more desirable because of the alum PBR calipers and the 11.7" rotors. The appropriate 1LE combination valve would be a bolt-in and the parking brake wouldn't be an issue.
Either way, if the gear ratio is different than the one in your car, you'll have to swap drive and/or driven gears in to make the speedo read correctly.
More info that you may find interesting:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old May 22, 2011 | 06:38 PM
CalimaroRS's Avatar
Car: 91 Camaro RS
Engine: 305ci
Transmission: M5
Re: Rear Axle Swap
Thanks and mine is a 10 bolt
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
