Will a 225/60/15 fit on a 10in rim?
Old Jun 13, 2009 | 12:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Is that to wide for a 60 to fit proper and no worries about it coming off in a hard turn n such???
I like that bulging side wall look.
Old Jun 13, 2009 | 02:41 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Will a 225/60/15 fit on a 10in rim?
a 225 tire will be super stretched out on a 10 inch rim.
i dont think you understand how the tires are measured...
225/60/15
225, the first number, indicates the treadwidth in millimeters.
225 millimeters is 8.8 inches
60, the second number is the width of the sidewall, in relation to the treadwidth
225 x 0.6 (aka 60%) = 135
therefore, you have 135 mm tall sidewalls... or 5.3 inches
15, the last number is the inner diameter of the tire, indicating the wheel size it can be used on.
15 inch tires go on 15 inch DIAMETER wheels
if you want a bulged sidewall, on a 10 inch rim, you should be looking at tires in the 295 area.
a 295/50/15 will be pretty close to stock height, but a lot wider
Old Jun 13, 2009 | 02:54 PM
Stephen's Avatar
Car: 87 GTA
Look up that tire on http://www.tirerack.com
Not only is the tread width of a 225 less than 10", so is the sidewall width. The metal of the rim will be the widest part, meaning if rub something, like a curb, its gonna eat your rim instead of having the rubber to protect it.
Get a narrower wheel or a wider tire.
Old Jun 13, 2009 | 06:53 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I hate to say it, but this question would be better suited on VW forum. Not trying to bash; you'd just get more realistic and accurate responses of people that have done it.
Old May 22, 2011 | 05:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Got a chance to try this, just mounted an old tire up.
went on easier then thought, even being half dry rotted.
onlything is the tire doesn't touch the rim edge as tight.
Here is a 225 on a stock rim
Old May 22, 2011 | 05:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Oops just noticed this is in the wrong section, maybe we didn't have wheels n tire section in 09 when I first made it?
Old May 22, 2011 | 06:20 PM
Drew's Avatar
It's been there since the forum has been in this format... Circa 2000.
Sorry man, but that is hideously ugly.
Old May 22, 2011 | 06:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
What size rim is stock for a 86 Firebird, 8in?
225s do look full on a stock 3rd gen width rim, but I got the same 225s on my V8 car and they look waff, like they got more room to give. Must be a 7in rim?
[the 10 in rim in pic is the match to these below]
Street Lethal
Apr 30, 2019 12:14 PM
Djmathis123
Sep 29, 2015 01:36 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
rh76camaro
Aug 29, 2015 11:04 AM
