Pro 5.0 shifter for 84 Camaro cannot shift into 1,3,5
Old May 17, 2011 | 08:18 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Hi everyone, I bought a pro 5.0 shifter for my 84 camaro. I followed a tutorial here at third gen( http://www.cardomain.com/ride/186985...camaro/page-10) All went well with the install accept now that I have the shifter installed I cannot get 1,3,5 gears. The shifter slips into 2,4,and reverse with no problem. It doesn't seem to matter what I do with the stop bolts as I can back them all the way out or in and no matter what I do I cannot get 1,3,5. I must be close as I push the shifter forward, because I try to put it in 1st gear and when I ease the clutch out the shifter pops back into neutral. I have done a ton of reading before I tried this instal but yet here I am missing gears. any ideas or suggestions would be appreciated.
onthedownlow
Old May 17, 2011 | 10:28 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Pro 5.0 shifter for 84 Camaro cannot shift into 1,3,5
make sure the shifter ball is in the socket inside the transmission...shift rail.... if not it wont go into gear correctly
Old May 17, 2011 | 10:41 PM
Engine: 355
I was pretty sure it was snug in the socket inside the tranny, I even applied a dab of grease to the ball prior to instal. Is there a chance I got the wrong pro shifter?? It says 82-92 camaro /firebird T5 but thanks for your help.
onthedownlow
Old May 17, 2011 | 10:45 PM
I JUST thought of something else........remove the 4 bolts and rotate the shifter 180*.........if the shifter is installed incorrectly or the shifter is not in the rail correctly it will not operate as it should
Old May 18, 2011 | 09:44 PM
Engine: 355
Well I haven't had a chance to work on the shifter any further but I also noted that my stock shifter **** will not fit the pro 5.0. The pro 5.0 has a threaded end for the shifter **** , but my shifter **** doesn't screw on like most. To remove my shifter **** I have to pop the little plastic insert off the top(shift pattern)and then use a socket to remove the bolt. In any case I do need a shifter **** now too, so if anyone has a shifter **** for sale or knows where I can get a new one please pm me, I guess I will be looking for a new shift boot, as the boot opening is too small and the shifter wont fit through it. thanks and all advise appreciated.
onthedownlow
Old May 19, 2011 | 07:56 AM
1986350's Avatar
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
Hey guys not to barge in but I have a b&m short throw shifted where you don't have to set the stops and it fits the factory shifted ****. Had it installed maybe 2 months pm if your interested.
Old May 19, 2011 | 07:45 PM
Engine: 355
Well I am embarrassed as I was having a blonde moment, as it turns out I had it on backwards. Whats funny about this is that I am usually the one laughing at people who make dumbass mistakes....guessing I am the dumbass this time (: oh well I can admit when I've screwed up...hahah, on a lighter note I can now get all gears perfectly. Just trying to fit the shifter ball and boot and I will be ready to take her for a ripp....can't wait !!
onthedownlow
Old May 19, 2011 | 10:24 PM
onthedownlow
see post #4...............exactly what i was talking about..not to worry it happens to the best of us sometimes.
Old May 20, 2011 | 05:21 AM
Engine: 355
Hey Badass I did think of you as soon as I realized my mistake, lol but yeah like you say it happens to the best of us. Thanks for your help man.
onthedownlow
Old May 20, 2011 | 09:26 PM
no problem.glad i could offer suggestions
Old May 21, 2011 | 05:54 AM
Engine: 355
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
