700R4 Missing 3rd Gear
Old May 18, 2011 | 08:18 AM
joshhsi's Avatar
Car: 1991 Camaro Z28
Engine: 305 TBI
Transmission: 700r4 w/B&M Shift Kit
I have a 91 z-28 with a 305 ci, 700R4 with a hight stall converter and a shift kit. About 75% of the time when I am really on the gas the the trans will go to shift into 3rd gear and completely miss. It shifts fine when under normal load and I just replaced the filter and fluid last week. The fluid was still good and I didn't see any pieces in the pan. Any suggestions on what the problem could be?
Old May 18, 2011 | 12:26 PM
Rob 70's Avatar
Car: F250,83 diesel, many more
Transmission: 4R100, 700R-4
Axle/Gears: 3.73, 3.42
Re: 700R4 Missing 3rd Gear
What kit do you have in the trans? BM, Transgo, Can you manualy hold 3rd gear?
Rob
Old May 18, 2011 | 12:35 PM
joshhsi's Avatar
Engine: 305 TBI
It has a B&M Kit in it. I can manually go up through the gears with the same result most of the time (missing 3rd). When it does miss third, i only have to get off the gas and it will drop into gear fine. Once it is in third, I can keep it there as well. I hope that answers your question?
Old May 18, 2011 | 01:09 PM
Rob 70's Avatar
Check your tv cable and make sure your cable didn't move a few teeth. I have seen these things wear over time and not hold in the position they should. When you hit WOT they will jump. The TV pressure is what will hold it in 3rd till the governor goes fast enough and moves it to 4th.
Rob
eightsixseven
Dec 16, 2024 01:50 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
