need help figuring tranny out
Old May 19, 2011 | 11:09 PM
Dougie91's Avatar
Car: 1992 Firebird convertible
Engine: 5.0 tbi
Axle/Gears: stock, slow and steady 2.73's
So i just got my transmission replaced (700r4) because i killed mine and the mechanic said it had corvette servos and something else i cant remember. the car feels like it needs more gas to take off normal but when accelerating it doesnt drop the rev as far as it did before when shifting. but when nailed off the line it feels quicker and when in D it shifts at higher rev than it used to. what ya think has been done to it?
Old May 20, 2011 | 10:06 AM
Guest
Guest
Posts: n/a
Re: need help figuring tranny out
This is all easily explained by a looser, higher-stall torque converter. This is a performance thing. See, if you used a bigger cam, your torque band would be shifted to a higher RPM range. You'd have less torque off-idle than stock. So the higher stall speed lets the engine get into it's higher RPM band before having to pull the car.
You may get less MPG in town.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
