Will this tranny work?
Old May 20, 2011 | 08:34 PM
Shane4524's Avatar
Car: 1986 Camaro IROC Z28
Engine: 5.0L 305 TPI
My 86 camaro needs a new tranny. Some of you may have read my many other threads about it. Well, I am finally coming down to a decision. I have found a 700r4 from an 86 cutlass. Will this fit in my car and what should I do? The owner works at NAPA and said I would have to change the tranny fluid and change two different seals on it because it has been sitting for a little while. He is a friend of mine and said he is confident in it that he would put it in his vehicle. He just heard I need one and said he would sell it to me. It has about 70k miles on it.
Old May 20, 2011 | 10:34 PM
Guest
Guest
Posts: n/a
Re: Will this tranny work?
Cutlass should be 200-4R. Compare the shape of it's pan to the shape of your pan. If they're obviously very different...
A 200-4R is not a direct interchange for a 700R-4.
Old May 21, 2011 | 12:39 AM
Shane4524's Avatar
They told me it was a 700r4. I will check again with them though.
Old May 21, 2011 | 04:19 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Only a 700r4 from 3rd gen will be direct bolt it
Why--- because torsion bar location and crossmember bolt up (different driveshaft lengths w/diff models
You can buy a relocation bracket for the torsion bar and modify the bolt holes or location of the x member though and it will work
Old May 21, 2011 | 11:02 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
on top of maybe doing a slight mod, you can bolt any trans to any engine, you just buy an adapter plate, in the $100 range for most automatics.
If your matting a odd ball stick up, it may cost more for clutch parts.
but you can bolt up anything if you got the need.
Also note around 70,000 miles is the point of no return for a 700R4, if the fluid has never been changed up to that point, a whole bunch of new fluid is bound to losen gunk and cause a problem.
Those are picky trannys, they work or don't.
Id have no problem grabbing any random unknown history Th350 or Th400 form a junk yard and bet on it before a used 700
Old May 21, 2011 | 09:12 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
you can take your tailshaft housing off and put it on any other 700r4. that solves the torque arm problem. like said above id check the pan and make sure its not a 200r4. both are 4spds but length is different. first thing before buying it is too check the fluid. pull the dipstick and put a few drops onto a clean piece of white paper. if its not clean and reddish/pink then don't bother because 700r4s are very finicky if not taken care of. either way id change input/ output shaft seals, dipstick grommet, and tv cable o ring. mise well do it right the first time.
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
