car is vibrating at lower rpms.
Old May 25, 2011 | 09:53 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
just put in a used rear end in my 85 camaro. never vibrated before but old rear end had a blown out axle bearing where the driveshaft yoke goes into the rear end. i think this may have thrown the driveshaft off balance from driving on it broken for awhile. when i swapped out the driveshaft for my older driveshaft the vibration cooled down a little. the vibration seems to be worse at lower rpms like 45mph in 5th or 60mph in 6th. anyone have any ideas?
Old May 27, 2011 | 09:23 AM
slowgta's Avatar
Car: 89 GTA
Engine: 383 SuperRam AFR 195s
Transmission: Pro-built 700R4
Axle/Gears: 3.27 9 Bolt
Re: car is vibrating at lower rpms.
Did you re-use either of the u-joints when you swaped driveshafts? The rear U-joint from the old diff probably took alot of abuse running with a bad pinion bearing.
Old May 31, 2011 | 11:39 AM
n8sz28's Avatar
Car: 85 camaro z28
No the other drive shaft had its own u-joints I did visually inspect the u-joints and they didn't seem to sloppy but it could be the problem
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
