I NEED HELP FINDING GEARS
Old May 26, 2011 | 11:00 PM
F_BODYKING NC's Avatar
Car: 1988 IROC-Z ,1991 RS
Engine: 350 TPi , 305 TBI
Transmission: 700r4 ,t56 sixspeed
Axle/Gears: ?
HAY GUYS I AM LOOKING FOR A SET OF GEARS FOR MY 88 IROC Z IT IS AND DANA 44 DISK BRAKE REAR END AND IT WAS FACTORY IN THE CAR BUT I AM TRYING TO FIND A SET OF 4:10 GEARS FOR HERE CANT GET MY 60 FOOT TIME DOWN AT THE TRACK RUNNING 95 TO 97 MPH THROW THE TRAPS AND ONLY RUNNING 15 TO 15,5 HELP PLEZ I NEED HELP
Old May 27, 2011 | 12:57 AM
Guest
Guest
Posts: n/a
Re: I NEED HELP FINDING GEARS
Sort of like this?
http://www.ringpinion.com/ProductDet..._Standard_Gear
This may not be the correct part number, because look here:
http://www.ringpinion.com/DiffList.a...pe=Dana_Spicer
look how many variations they're showing for the D44!
But you say it's a stock 88? Then it's probably the 9-bolt, not a Dana.
http://www.ringpinion.com/DiffDetail...2+Borg+Warner+
If so, it's 3.73:1 or swap to a different axle.
Old May 27, 2011 | 07:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a dana44 was never factory installed in any 3rd gen, they were only installed in the firehawks (91-92), built by SLP, and available over the counter by GM.
If it is a dana 44 is was swapped in at some point.
ifs its indeed the original axle, are you sure its not a 9 bolt?
Old Feb 27, 2012 | 07:48 PM
Axle/Gears: ?
i know it has been a really long time. i have found out by calling slp found out it is an Aulstralian 9 bolt. and have only found one place to get gears it looks like almost 900 for gears and a carrier. so i have been looking for a 4 gen 10 bolt rear cheap i live in jacksonville nc seeing if there was any thing close to the area
junkcltr
Aug 2, 2019 11:12 PM
jklein337
Sep 19, 2018 06:23 PM
lt1z350
Sep 29, 2015 01:50 PM
