Transmission line thread size?
Car: '85 Camaro
I've tried a search and didn't find anything. But my question is, I bought a th400 with 6AN fitting in the feed/return holes, now what size are the threads on the stock transmission hard lines that go into the tranny? I basically need a fitting that would connect the two. So basically it would screw onto the thread of the tranny lines and then onto the 6AN fitting of the tranny itself. Any ideas?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Transmission line thread size?
The fittings that going into the transmission itself are normally 1/8" pipe thread. The hard line is normally 5/16" brake line fittings.
Car: '85 Camaro
Well I'm bringing this back up.
I removed those -6AN fittings that were in the tranny and tried to screw in the factory tranny hardlines. Must not made a good seal because It was leaking.
I put the -6AN fitting back into the inlet/outlet ports now. Is there a fitting that will adapt from the -6AN to the factory 5/16 hardline threading?
I'm running out of options of what to do because I also will be getting a tranny cooler soon, so I want to route the lines all at once. I was thinking of just getting a -6AN to hose barb fitting and get the push-loc hose to route it. But the hose would be close to the long tube headers
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Yea ive ran into that problem. A trans shop should have the small fittings that go into the tranny to use you factory hard lines again. Its wierd how the lines will thread in without them but they wont seal... Must be a failsafe so you dont strip the case.
-6 with pushlock barbs works very well too. Heat shield where needed!! Goodluck
Car: '85 Camaro
I'll check with trans shop and see if they have that fitting. So the pressure ports on the trans are 1/8NPT or 1/4"? I'm confused on that part as well.
IF i do the barb end, I was also thinking of wrapping the headers where it gets close, but I don't still.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: '85 Camaro
Car: '85 Camaro
Anybody else might know what fitting would work for the hardline fitting to the -6AN one?
Engine: 383 Carb
Transmission: 4L60
You have male -6 AN fittings on the transmission? You can try flaring the ends of the hard lines for tube nuts, but it probably won't line up well. Better would be to cut back the hard lines before flaring, and then use short pieces of hose between the transmission and line.
Car: '85 Camaro
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Why not run hose all the way ? No cutting/flaring involved, just have to get the correct fitting, and then hose.
Just to verify the thread size, I would go to a car parts store, buy a bunch of different fittings, including 6AN, then take them home, try them on the transmission, and return those you didn't use.
Question regarding this though since I'm using rubber hose between the radiator/B&M cooler combo, and the transmission, should I put heat insulating/protective sleeve on the hose ? Because it is after all rather close to the exhaust system.
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
