4l60e shifting problems please help!!
Old Jun 1, 2011 | 06:44 PM
futureBAirocz's Avatar
Okay, i got an 87 iroc with ls1 with 4l60e behind it, when i first got it started and drove it it only had 2nd and 3rd gear. We figured out guy sent use the wrong PCM, he sent me the one for a 6 speed.. So i had my tuner guy do a segment swap on pcm which changes it to an automatic. the other day i put pcm back in and drove it, now it only has 1st and 2nd gear.. i put it in drive or overdrive and the rpm just shoots up and isnt catching. but it starts out it first in drive and OD. i dont knowwhat to do!! lol please help
Old Jun 2, 2011 | 07:12 AM
Pro Built Automatics's Avatar
Re: 4l60e shifting problems please help!!
If the fluid is still good, and it was working ok before then the computer could still be the problem. If the fluid is burnt or there is material on the bottom of the pan, then the 3-4 clutch pack could be gone.
Old Jun 2, 2011 | 11:53 AM
Rob 70's Avatar
Car: F250,83 diesel, many more
Transmission: 4R100, 700R-4
Axle/Gears: 3.73, 3.42
You can unplug the transmission and you will have manual 2-3 R. If you have manual 2-3 and with the trans plugged back in you only got 1-2 either the B solenoid in the trans is stuck on which is unlikely or ECM problem. Do as Probuilt said and pull the pan look for garbage.
Rob
Old Jun 2, 2011 | 08:51 PM
fluid is clean and nothing in oil pan, its gotta be pcm, i hope. my tuner is gonna check on his computer and see what it says. is there anyway having no speedo would be doing something? the vss is plugged in but i dont have speedometor yet
Old Jun 3, 2011 | 01:00 AM
The speedometer not working will cause this.
Old Jun 3, 2011 | 10:03 AM
Rob 70's Avatar
Like Probuilt said no speedo will cause this. The pcm has to see speed to know when to turn solenoids on and off. Also the right gear ratio and tire size input has to be in the pcm or the shift points will be way off.
Rob
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
dhonda200
Aug 11, 2015 11:50 PM
