tv cable 700r4
Old Jun 1, 2011 | 08:54 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
tv cable 700r4
are the tv cable's on a tranny for a 305 tbi shorter than the one's for a 350tpi? I've just got my swap in and the tv cable dosn't seam to be long enuff.Either it's not running the proper route or there is a difference.
Old Jun 1, 2011 | 10:38 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: tv cable 700r4
thier is a difference. The TPI cable connects on the throttle body more towards teh front of the engine. So the tbi cable will not work
Old Jun 1, 2011 | 11:08 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: tv cable 700r4
yup the tpi cable is around 4 inches longer give or take.
Old Jun 1, 2011 | 11:28 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: tv cable 700r4
I was afraid of that.I've already taken the iroc cable off the broken tranny and figure I can tie a string onto the end of the tbi tv cable so when I pull it out it will be easyer to get the right one back in. thanks for your input.
Old Jun 6, 2011 | 05:18 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: tv cable 700r4
OK,got the cable changed and everything seamed to work good exsept for the first few miles it didn't want to shift until about 3500rpm.after a 7mile driver shifting went fin.So I tryed to kick it down into passing gear at a 45mph speed and nothing.tryed again at 55 and still no kick down.whats up?I'm preaty sure theI got the tv cable hooked up.I had to do it with the tranny alredy in and no one to keep presure on it while I lowered the base in place.Would it shift ok if the cable had sliped off?Got a few othe things going on but thoughs dont belong in the tranny board.Thanks!
Old Jun 6, 2011 | 08:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: tv cable 700r4
Did you adjust it after installing it?
Old Jun 7, 2011 | 01:53 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: tv cable 700r4
no,It was the same cable that was in the car to start with.Didn't think it would be different.What would the tranny be doing if the cable sliped off the little wire conector in the tranny?That thing was sort of hard to keep hooked and ease the cable housing down from the angle I was at.
L0tuS
Oct 4, 2015 08:07 AM
RS Reaper
Sep 27, 2015 07:04 PM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
HikoriYami
Sep 21, 2015 07:11 PM
