locking up problem sum 1 help plz
Old Jun 10, 2011 | 02:42 AM
pjp209's Avatar
Car: Gone
rear end locks up when i try to do 360s can sum1 tell me what mite b wrong with the rear end idk much bout it i can hear grinding sounds when i turn slow......... its a 10 bolt 323s 28spline
Old Jun 10, 2011 | 10:41 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: locking up problem sum 1 help plz
First off, please use proper english and grammar. Then we might actually be able to decipher what it is you are trying to say.
Old Jun 10, 2011 | 03:47 PM
pjp209's Avatar
Car: Gone
stfu stay OUT
Old Jun 10, 2011 | 03:55 PM
pjp209's Avatar
Car: Gone
if you dont have anything good to say
Old Jun 10, 2011 | 04:21 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
what OZZ was saying is that he did not understand the question . i must say that neither did i . just a comment , your not going to get much help if you continue with sarcasm ( "STFU stay out" ) .
Old Jun 10, 2011 | 04:31 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Rear end noises can be hard to diagnose. Does it make more noise turning in one direction vs the other? If it does that would make me think wheel bearing.
When you say locks up are you saying it's skipping/hopping?
Old Jun 10, 2011 | 05:13 PM
pjp209's Avatar
Car: Gone
it makes more noise when i turn left. and the locking up part happens while im burning out. it will do 2 tires then 1 if thats helps a lil
Old Jun 10, 2011 | 05:20 PM
pjp209's Avatar
Car: Gone
dont post here if you dont understand the ?. im no pro an i dont think you are either
Old Jun 10, 2011 | 05:24 PM
pjp209's Avatar
Car: Gone
how can i check them. thanks 4 replying without any ****talking
Old Jun 10, 2011 | 06:17 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I'm not an expert, I don't think anyone on this board will claim to be. We all have varying levels of experience in maintenance and with these cars.
I was trying to make a point that if you write an intelligent statement instead of a runon sentence using text shorthand you won't get people making what you perceive to be silly statements. I had to read it four times just to get it to make sense But, enough of that. Since you do actually have a problem...
Could be your limited slip differential is going bad or you have another problem with your axles. You will have to take your rear apart to check the axles or the diff or take it into a shop and have them do it. What exactly is the sound? Grinding/popping? does the car sort of hop as you turn in that directions? Do you hear a whining sound when you drive? Either under acceleration, deceleration or at cruise?
Old Jun 10, 2011 | 06:35 PM
UNCLE TOM's Avatar
there is a wealth of information on this forum . people will be happy to share prior problems and fixes with you . but , they must know what the problem really is (without sarcasm) . as to myself , i don't consider myself a pro. . i have only owned 5 3rd gen. camaros , counting 2 parts cars . I AM , a retired Professional FAA & DOT licensed airframe and powerplant mechanic . i do know my way around with a wrench . oh well , good luck .
Old Jun 10, 2011 | 06:36 PM
pjp209's Avatar
Car: Gone
its not that loud yet. i only hear it when i turn left at slow speed like 5-15 mph. i put some additive awhile back maybe that messed it up. i think its posi cause when i powerbrake it it has 2 tire fire
Old Jun 10, 2011 | 06:39 PM
pjp209's Avatar
Car: Gone
[QUOTE=UNCLE TOM;4948016]there is a wealth of information on this forum . people will be happy to share prior problems and fixes with you . but , they must know what the problem really is (without sarcasm) . as to myself , i don't consider myself a pro. . i have only owned 5 3rd gen. camaros , counting 2 parts cars . I AM , a retired Professional FAA & DOT licensed airframe and powerplant mechanic . i do know my way around with a wrench . oh well , good luck .[/QU
Old Jun 11, 2011 | 07:12 AM
Engine: 383 SBC
Additive shouldn't mess it up. If you're talking about Posi Limited Slip stuff it only helps quiet down the chatter it's not going to fix grinding or etc if you have other problems.
Unless you feel comfortable pulling it apart yourself I would recommend taking it into a local shop. Local Tire/Service Shop here only charges $30-$50 for inspections to isolate noises and vibrations. They would tell me which wheel bearings or etc was bad on my wife's FWD car and I would just take it home, buy the parts, and change it myself. You pay a little more that way but it's far easier for them to diagnose and find the noises than me rolling around in my garage.
Also you might want to settle down and watch your language around here. Members that start trouble don't tend to last very long before getting banned.
Old Jun 11, 2011 | 04:43 PM
pjp209's Avatar
Car: Gone
30-50 overhere it will be like 130-150 thay try to get rich. its california
Old Jun 12, 2011 | 03:50 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
When you say 360's do you mean U turns, or are you spinning all the way around till you are facing the same direction?
Old Jun 13, 2011 | 12:33 AM
pjp209's Avatar
Car: Gone
any tunrs
Old Jun 13, 2011 | 01:33 AM
any tunrs
Sounds like you goofed up your rear end pal.
Old Jun 13, 2011 | 05:58 AM
Engine: 383 SBC
What is this whirring noise?
Whirring noise only while decelerating at any or all speeds is most likely caused by bad pinion bearings or loose pinion bearing preload, and almost never by bad ring and pinion gears.
A howl or whine during acceleration over a small or large speed range is usually caused by worn ring and pinion gears or improper gear set up.
Rumbling or whirring at speeds over about 20 mph can be caused by worn carrier bearings. The noise may change while turning.
Regular clunking every few feet may indicate broken ring or pinion gears.
Banging or clunking only on corners can be caused by broken spider gears, lack of sufficient positraction lubrication, or worn positraction clutches.
Rumble while turning may indicate bad wheel bearings.
A steady vibration that increases with the vehicle’s speed can be caused by worn u-joints or an out of balance driveshaft.
Clunking only when starting to move or getting on and off the gas might be loose yokes, bad u-joints or worn transfer case or transmission parts.
Right from Randy's Ring and Pinion.
BRoss99
Aug 10, 2025 05:08 PM
someone972
Aug 30, 2015 12:52 AM
CORV3TT3
Aug 23, 2015 11:26 AM
g.l.mos
Aug 22, 2015 12:02 AM
1nastygta
Aug 8, 2015 07:38 PM
