Info and Help on T5
Old Jun 13, 2011 | 09:06 AM
jimbuck0's Avatar
Info and Help on T5
I have a T5 in my chevelle adn broke down on the Hot Rod Power Tour (tranny wore out so to speak). I am looking for a replacement and seems to be hard to find. Question, the non-world class was used from 83-87 and th world class from 88-92. Are they interchangeable? I have a mechnical clutch setup and wondered about the newer ones and if they used the hyd clutch setup.
Thanks,
Jim Buckingham
Old Jun 13, 2011 | 10:05 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Info and Help on T5
The change from mechanical to hydraulic clutch affected only the bellhousing.
Any v8 third gen T5 bolts in place of another.
The speedo gear on the output shaft needs changed (if different)
and the vss and speedo gear need swapped out to what was in your old trans.
That's it.
Old Jun 13, 2011 | 10:08 AM
jimbuck0's Avatar
Thanks, Now all I need to do is find one. They seem hard to find anymore.
Old Jun 13, 2011 | 01:52 PM
jmd's Avatar
jmd
If it's a W.C. box, a rebuild wouldn't be a terrible option.
What's the metal tailhousing tag (or decal on top) have as a 1352-xxx number?
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
