"Nice" shifter for a 4L80e swap
Old Jun 15, 2011 | 02:21 PM
83 Crossfire TA's Avatar
I'm looking for recommendations for a shifter for a 4L80e swap (it currently has a T5 in it if that matters, I have a decent stock shifter in my parts car but I don't know that I want to dot that).
What do I mean by "nice":
- it's sort of a race application but it will see a lot of street time, function is the most important but I'm trying to stay away from something clunky and unrefined
- _I think_ I want a rachet shifter (I want to make the same action shifting through the gears, although I've never owned a pro stick or anything like that the "push it forward, pull the lever, push it forward..." different actions kind of turns me off.
I like the TCI street fighter for the new mustang, but it is completely different then the normal street fighter and uses the mustang's linkage, lighting and other parts and has a 5 speed gate, so I've been told that it will be next to impossible to adapt it to anything else:
The Quicksilver is OK, but not thrilled with the chrome bezel and would probably put a different **** on it if I was to do that.
I don't like things like the Megashifter and some of the ones are pretty old school, I either want clean and modern or race functional...
Any ideas? What do you guys like? I guess that most 3 speed shifters are available for 4 speed and they shouldn't be a problem to make work...
Old Jun 15, 2011 | 02:22 PM
Re: "Nice" shifter for a 4L80e swap
While I'm at it, maybe someone can point me at a shop for some tranny and chassis work in MD:
https://www.thirdgen.org/forums/mid-...ml#post4952597
Old Jun 15, 2011 | 05:26 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I like this brand. Comes in different configurations, front cable, rear cable, 2, 3, or 4 speed.
http://www.precisionperformance.com/kwik2.htm
Old Jun 15, 2011 | 09:02 PM
Looks like you linked to the II but showed a pic of the I. Does that have the same action for shifting into all the forward gears or is it like a pro stick type thing? what does the thing at the top do?
Old Jun 15, 2011 | 10:05 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I picked up a Hurst quarter stick for my 4l80e swap. They don't make them for 4 speeds anymore but I lucked out and picked one up off of craigslist in Texas.
Old Jun 15, 2011 | 10:10 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
tuboaction makes the cheetah shifter. check it out.
Old Jun 15, 2011 | 10:17 PM
While I love the look of the pistol grip quarter stick (it would be just right for what i'm looking for), the push forward, pull lever and push forward, reliease lever, relax stick and push forward again shift pattern really bothers me. I'm not sure I get the reason for it and I could see at times missing a shift because of it. I don't get why it can't be push forward without the lever for all the forward gears and just use the lever to get into reverse, park and to pull it all the way back...
Why did they quit making the 4 speed???
Old Jun 15, 2011 | 10:19 PM
The turboaction cheetah and the similar winters shifter are great functioning shifters, but man are they cheezy and dated looking... No go there...
Old Jun 15, 2011 | 11:41 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
From the video I saw it works like a slap shifter kinda when in low gear. You just smack it forward until you hit neutral, no pulling on the handle at all. You have to pull the front handle to shift down to low gears and out of park. The button on top is to shift from reverse to neutral or vice versa, you have to pull the front handle then push down with your thumb on the top button. Its their way of making a reverse lockout, but you only need one hand to operate it.
The shifter in the pic is for a rear cable mount, the front cable mounted version is the same main body, just the handle is turned 180 deg.
I hope my explanation makes sense, I tried to find the video of one being demonstrated but its gone.
Old Jun 15, 2011 | 11:48 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I dont like the quiksilver shifter. But the Megashifter and z gate i love. the ratchet is a no brain shifting method and its not too bad to pull up on a lever to switch from P to R to D etc.
Old Jun 16, 2011 | 07:33 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Only make it for 3 speeds.
Old Jun 16, 2011 | 07:34 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
It does sound weird when you talk about it like that. But driving one feels normal. I am not sure why they quit making 4 speed ones. I tried to order one and found out they were discontinued. So I hunted around till I lucked onto one.
Old Jun 16, 2011 | 07:36 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Also TCI just came out with a new 4 speed shifter.
Old Jun 16, 2011 | 01:23 PM
What new TCI shifter? I don't see anything even newish on their site besides the mustang one that I mentioned
Old Jun 16, 2011 | 01:38 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
http://www.tciauto.com/Products/TC-%...ters%27-0.aspx
Old Jun 16, 2011 | 08:25 PM
that just links to the shifter's site, which one are you talking about?
Old Jun 16, 2011 | 09:29 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
i clicked it it links to a tci fast gate shifter it looks too old school for you.
Old Jun 16, 2011 | 09:40 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
That is the one I am talking about. Not allot of shifters for 4 speed out there.
Old Jun 16, 2011 | 11:01 PM
If you notice the address doesn't change when you click on the other shifters... yea, the fast gate probably won't work unless I wanted to make a new handle and stuff for it (I haven't ruled that out if I find a shifter that I really like the operation of at a good price)
BewleyBizzIROC
Feb 3, 2020 09:52 AM
camaro11j
Sep 19, 2018 08:49 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:55 AM
NBrehm
Aug 25, 2015 11:49 PM
