lt1 T-56 squealing help
Old Jun 18, 2011 | 11:41 AM
thabeast's Avatar
Car: 84' trans am
Engine: 305 h.o
Hey guys I installed my t-56 outta a 95 t/a into my 84 t/a it has a newer block 1pc rear main seal. Used F1 Racing Chromoly flywheel, stage 3 or 4 sprung clutch pressure plate forgot brand. Now everything went pretty smooth, cause we put the bellhousing on first had to use bolts to pull the tranny in a lil mostly cause of the pins. On start up you could hear a loud squealing and idle in and out of gear putting it in gear driving when under load a lil less its off an on. I had to redo the exhaust and got under it and its coming out loud right from the bellhousing. I read a few forms and people seem to say its a glaze from the flywheel. Just would like your opinion, throwout bearing is new so is slave cyl, Adjustable is in good shape along with pilot bearing (less than 6 months old good condition). Kinda hoping its not an internal transmission bearing but once I could be under without open headers its deff from the bellhousing. Thanks in advance I tried to be descriptive as possible.
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
L0tuS
Sep 4, 2015 11:16 PM
