the source of my leak
700r4 4speed trans has been leaking bad.
It drips from the bell housing cover drain hole and the bottom passenger side bolt that holds up the housing.
Excuse my lack of knowledge on this part. When I take the cover off the converter is completely dry(so it couldnt be the front seal?), but the plate across from it is wet all around the edge on by the bolts as well.
Is this the trans pump seal leaking? Ive replaced the pan gasket and filter and checked the cooling lines and dipstick tube seal, which were good
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: the source of my leak
Mine does something very similar - drips from the front pan rail, and is wet a little way above the pan rail, but not all the way to the front seal - so I reckon it's not the seal.
It used to leak heaps from many spots. Changed the gasket a couple of times, slowed it down by about half for maybe a month-ish, but always came back. Pulled the pan again, and beat all the bolt holes flat - were all bent upwards. This got rid of all but the front leak where the rail is really thin, but permanently slowed it down.
Much later I got a new pan which almost eliminated it - but it still weeps very slowly. Decided I could live with it.
I dont believe mine to be leaking from the pan rail, and I dont know if it would hurt to try and bend the pan rail a bit?
I believe it to be leaking from the part thats between the pan and the converter, where the red line is. I dont know the technical name sorry
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
looks like the transmission pump gasket may be seeping..i would also change the input shaft seal on the pump as well while your there.there is also a little o-ring at the tip of the input shaft seal.change that too..........and be carefule putting the pump back in place as to you dont want to damage the teflon seals on the input shaft......
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Most of the time when the front pump is leaking its because of the pump bushing is worn
1Aauto
Sponsored Vendors
24
Mar 27, 2018 11:59 AM
1Aauto
Sponsored Vendors
Nov 9, 2015 02:25 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 01:00 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
