700r4 woes.
Old Jun 27, 2011 | 04:15 PM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Engine: Stock 3.1 v6
700r4 woes.
Specs, just in case they matter:
1990 Camaro RS
3.1 v6
700r4
All stock
Where to start... Well, from takeoff I guess.
Initially taking off from a stopped position when cold the car makes decent power, but seems like it's being held back (presumably by the transmission). In other words, it feels like the transmissions is dragging. It's also choppy when cold and in first, almost like you have to floor it to make it go anywhere.
You also have to take it up to near redline to make it shift from 1-2 (but only the first time it makes the shift, each subsequent 1-2 shift is fine).
After all of this, it seems to work fine, and even shift too early sometimes.
Couple of additions:
What would be the symptoms of having too much transmission fluid? (just curious)
I put in a new TV cable (thought that was initially the problem) and a new gear select cable.
Also, I have every gear except park. Park has the same characteristics as neutral. I also can't start my car in neutral... Weird.
Old Jun 28, 2011 | 10:33 AM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Re: 700r4 woes.
Bump for advice...
Old Jun 30, 2011 | 10:52 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: 700r4 woes.
Sounds like you may need to adjust your shifter cable to regain park. Symptoms for having too high a fluid level would mainly be foaming of the fluid. I've never experienced any radical effects from running a tranny over filled. As far as the first shift into second when cold, I'm not sure. How is your TV cable adjusted?
Old Jul 1, 2011 | 10:42 AM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Re: 700r4 woes.
It's adjusted according to the guidelines on the site.
Old Jul 7, 2011 | 10:12 PM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Re: 700r4 woes.
Bump.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
