Car hesitates to get out of overdrive
Old Jun 30, 2011 | 01:47 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
My car is an 88 camaro that I swapped the 2.8 out for a 3.1 and just got it back on the road. It has a 700r4 and everything runs great but I have a problem when it goes into over drive. If I'm going down the road at say 45mph in overdrive and I want to pass a car the car just won't go any quicker than 45 unless I floor it or put it into the D without the circle. At 45 in OD it will cruise at 2k rpm's and it runs fine unless I decide to go a little quicker. Maybe I'm just not used to the 700r4 but I don't think it should be doing that. At highway speeds (65-75) it does great its mostly at speeds under 55. TV cable adjustment maybe?
Old Jun 30, 2011 | 10:29 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: Car hesitates to get out of overdrive
Does it ever downshift by flooring it at any speed? I would verify the TV cable is connected and adjusted first.
Old Jul 1, 2011 | 01:00 PM
Car: 1988 camaro
Engine: cammed 3.1
Yes it does downshift but only when you floor it then when you get to your desired speed it goes back into OD. TV cable is connected, I disconnected it off the TB and pulled on it and it felt like it got tension when pulling it and I'm not sure how
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
