super t-10
Old Jul 5, 2011 | 11:31 AM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Transmission: 5speed
Axle/Gears: 3.73 detroit locker
super t-10
Anyone ever swap a t-5 to a super t-10? Is it easy?
Old Jul 5, 2011 | 01:21 PM
Guest
Guest
Posts: n/a
Re: super t-10
You'll need an '82 parts car, because the T-10 was the manual transmission for the '82 V8 F-cars.
But not that T-10. Just everything related.
But why spend $1600 on a T-10, when you can spend $1700 on either a TKO500, or a TKO600?
Or did you happen to find an old T-10 from a '78 Z28 or similar?
If you broke a T5, there are places that can rebuild it to hold 500 HP, for like $1500, plus you still have a stock-looking direct fit, that still has an overdrive.
Old Jul 5, 2011 | 04:04 PM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Re: super t-10
I found one locally on craigslist. Add says it's a barn find from a 77 Z that looks to be in good shape. Also says syncros look new. May have been rebuilt before storage $225.
Old Jul 5, 2011 | 04:07 PM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Re: super t-10
My t5 has trouble ingaging 1st and reverse. I just replaced my slave also.
Old Jul 5, 2011 | 06:08 PM
Guest
Guest
Posts: n/a
Re: super t-10
Possibly a bent shift fork?
Find some ID codes on that T-10, possibly stamped, or on a tag. You can get enough for it to buy a good used WC T5. Sell it on the NastyZ forum.
Old Jul 5, 2011 | 08:26 PM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Re: super t-10
There are times that it works and shifts fine. But sometimes I have to turn it off put it in reverse and then restart it. The problems are only recent. The 355 has been in it for over 4000 miles. Not sure if it's a WC or not I should check it. It does leak a drop now and then, no big puddles.I did put some lucas atf stop leak in it. Would that harm it? It said it was also good for manuals that use atf.
Old Jul 5, 2011 | 09:07 PM
Re: super t-10
Sounds like a clutch problem to me. The trans pretty much can't cause that symptom.
Which did you use; a pilot bushing, or bearing?
Old Jul 5, 2011 | 09:27 PM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Re: super t-10
Not sure. Bought the car last year with this way.
Old Jul 5, 2011 | 09:30 PM
Re: super t-10
Not sure.
I kind of suspected...
Try putting one in.
Old Jul 6, 2011 | 03:47 PM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Re: super t-10
Could it be the pivot ball. That would be easiest to check first.
Old Jul 6, 2011 | 05:47 PM
Re: super t-10
Check it and see.
Old Jul 6, 2011 | 06:38 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: super t-10
Is it hard to put in? Not at all, if you have the necessary pieces from an '82 F-body. But, you're not saving money when you also have to get a different bellhousing, driveshaft and shifter, then spend more on gas without overdrive. A new aftermarket bellhousing to bolt the T-10 in and use 3rd gen hydraulics is $450, new alum. driveshaft is $300(?) and the shifter could be tough to find: https://www.thirdgen.org/forums/tran...ing-plate.html
no green
Jan 9, 2016 09:22 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
