Master, Slave U bolts
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Clutch master and slave u bolts.......Where can I get them at?
I'm about to start on my swap, and the (so called) pedals and hydraulics came with no u bolts. Could I just use some generic u joint U bolts from the 'Help!' section at my local parts store, can I get away just bolting them on using bolts instead, or do I have to use OEM u bolts? I found the one for the slave, but the master is what I'm concerned most with.
Also, does anybody know the size of the shifter bolts.....those were missing as well.
Car: `86 SS / `87 SS
Re: Master, Slave U bolts
No on the u-joint bolts fitting.
master cylinder u-bolt PNs:
old no. 14076942
new no. 12568902 which fits 100% of manual 84-02 f-bodies.
bolts are M8 x 1.25.
old no. 14076942
Car: 86 Z28
Engine: Built 312
MUCHAS GRASSYASS!
That's what I love about this place.....you can search and search, if you don't find it- ask and ye shall receive!
UltRoadWarrior9
Sep 2, 2015 08:24 PM
