Auto problems...again
Old Jul 11, 2011 | 01:52 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I have a couple of problems, that I think may be all part of a specific problem.
First, I know my TV cable is set correctly!
The trans also is NOT slipping.
The tranny fluid is pink, and does not smell burned. I know this because it leaks a little.
1. Shifting from P->R or P->D, there is a pretty good jerk. It is not smooth like modern trannys.
2. Shifting from 1-2 under light throttle, is pretty violent, and gets SLIGHTLY better when it warms up. With cold tires, it will even chirp going into second.
3. When going around corners, the tranny tends to be in a higher gear (or 2) than it should be in, and I have to press the gas a bit to have it shift down to the next lower gear. It lugs, kinda like trying to go around a corner in a manual trans car in 5th gear at 25 mph.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
