Universal Joint Replacement in Alum. Driveshaft
Old Jul 24, 2011 | 03:10 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Ok am i failing to see something here or do you really need a press to get the old one out and new one in
i know on my steel one all i had to do was to heat up that "glue" that GM used to hold the caps in and beat it out with a hammer and socket
soooo
Old Jul 24, 2011 | 03:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Universal Joint Replacement in Alum. Driveshaft
a big bench vise works.... thats how i do them.
the aluminum may have seized to the steel caps, making it a bit harder to remove. You really dont want to beat on the yokes, you could bend/break them...
Old Jul 24, 2011 | 03:24 PM
89RS_82Z's Avatar
ok i never done it with a vice, i know the answer is going to be so simple but how do i do it with a vice, since its going to have a jaw on each side of the caps
Old Jul 24, 2011 | 03:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
use a small socket on one side of the vise to push the cap, and a large socket on the other side, thats larger than the cap, to push the cap into. Think about it, pretty straightforward. Just have to have a good sized vise
Old Jul 24, 2011 | 03:36 PM
89RS_82Z's Avatar
duh
Old Jul 24, 2011 | 03:53 PM
turbinator3's Avatar
hehehehehe
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
MENINBLK
Aug 5, 2015 11:58 PM
NBrehm
Aug 5, 2015 07:57 PM
