4th gen gear swap
Old Jul 24, 2011 | 07:56 PM
dewfamily's Avatar
Car: 1991 RS camaro
Engine: 5.7
Axle/Gears: peg leg for now
4th gen gear swap
I got a 1991 RS with a peg leg. I have been trying to find a posi with at least 3:42 gears. As alot of you know it is getting harder to find. I have ran across a couple of deals though. One is from a 1989 Iroc, but I am thinking that even though it is a posi it probably is 2:77. The other though is from a 1994. I have read the thread about it being a couple of inches longer. So my question is, can I swap in the unit and gears into my housing? If so, will the bearings and all be usable? Any help would be greatly appreciated. thanks
Old Jul 25, 2011 | 04:46 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Re: 4th gen gear swap
All the internals are the same from 90-02. Differentials from 82-89ish won't work because they are 26 spline axles.
Old Jul 26, 2011 | 01:09 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
The 9 bolt will live longer and is a better design. 7 3/4 VS 7 1/2. There are still gears and posi units out there. I don't know why everyone doesn't use them. I had 500 HP and almost 600 torque on mine with 2.77 gears and could not tear it up and it had over 120.000 miles on it.
Old Jul 26, 2011 | 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some general info below that may be helpful in making your decision:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
