LS1 10 Bolt E brake cable HELP
Old Jul 26, 2011 | 05:28 PM
nhra-trans-am's Avatar
Hi guys,
I have just swapped in an LS1 10 bolt into my 91 Firebird and I am at a loss as to what to use for parking / e brake cables. The 10 bolt is from an 02 Camaro and my Firebird was originally a rear drum brake car.
I have searched and read the faq, but it seems no one seems has a straight answer as to what to use and all the part numbers listed are no longer valid. I saw the flynbye cables, but would prefer not to order them because of the move and wait involved.
Basically, I need to know what to get so that the parking / e brake cable will work.
Thanks in advance for the help.
Old Jul 26, 2011 | 05:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 10 Bolt E brake cable HELP
hawks has them too....
or, apparently, you can swap the cable tat runs from the e-brake handle to the tunnel with a 98-02 one and that will make the stock 4th gen cables work. I have heard this, have never do it. I have used Flynbyes and Hawlks cables, both work well, but i found the hawks ones to be a little on the short side, they work, but i would have liked to see them a inch or two longer.
Old Jul 26, 2011 | 06:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I prefer 'store bought', but there's always another way to skin a cat:
https://www.thirdgen.org/forums/brak...-ls1-swap.html
JamesC
Old Jul 26, 2011 | 08:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I simply used wire rope clamps from Home Depot, and connected the cars cables to the LS1 rears cables up inside the tunnel. Cost me about $6 in stainless steel clamps, took me about 20 minutes to connect, and has worked great for the last 5 years.
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
