Need help with bolting a wc t5 on a 1975 305 sbc.
Old Jul 28, 2011 | 12:48 PM
CjMtzSS's Avatar
Car: 1983 Camaro berlinetta
On my 1983 camaro there is a 305 that had a 3 speed trans on it. when I removed the trans i realised that the mainshaft had 10 splines so Im sure ima need another clutch to match the 26 splines on the t5. Would I need to replace the flywheel aswell? Or am I good with just the cluTch disc. I dont know where this motor came out of im thinking a 75 camaro, id v0605TWH . Do I need to get the clutch set? Also I notice the 3 speed was about 3 inches shorter than the t5 so the drive shaft is going to be to long and Is going to be replace with a shorter one am I wrong?
Info:
engine gm 35 3970010 e165 back side H7 509, 010 020
heads 3986339x
3 speed trans gm39 3925647
6bolt Bell housing CM 2 462606
Flywheel GM4 366861N
Clucth disc cd3842/484
Clucth plate C1675 PHT
Old Nov 13, 2012 | 06:32 PM
David Romero's Avatar
Re: Need help with bolting a wc t5 on a 1975 305 sbc.
I have a 1995 Chevy T-5 Transmission out of a Camaro (V-6) and I want to put it into a 1975 Chevy Camaro with a 350. Will I need a different Bell-housing or drive-shaft to do this. If anyone might have any info I would appreciate it.
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
86z89iroc
Oct 5, 2015 01:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
