Needs a new rear end for my 89 camaro rs v8
Where can I find a new rear axle for my 89 chevy camaro v8 with 700r4?
I destroyed my axle and it rusted so bad nobody will rebuild it.
Where can I get a series 3 axle to replace my series 2 axle for this car?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Needs a new rear end for my 89 camaro rs v8
The "series" is just the gear carrier (posi, open, gov-lock, spool etc). 2 and 3 series carriers just depends on what gear ratio you're using but you can also buy thicker gear sets to use a 3 series ratio on a 2 series carrier.
Do you need a complete diff, axle(s), gears or a posi?
The only axle shaft choices you have a 26 spline which was used up to 1989 and 28 spline which was used from 1990-1992. You can put 28 spline axles into an older car as long as you use the proper carrier for 28 splines. 1989 was a changeover year but the majority of the 1989 cars got 26 spline axles. Very few came with 28 spline axles. If you only need a 26 spline axle, any axle shaft from a 82-89 third gen will fit. Left and right axles are the same length in a third gen.
If you need a complete diff, any diff from a third gen will be a direct swap. Any 4th gen diff will also work but they are slightly wider.
Car: 89 Camaro RS
Engine: 305 v8
Transmission: Automatic(modified)
Lol cool, an answer to my question. I just bought my 89 Camaro the other day and dude said it needed new axles for the differential, now i see why everyone i ask says its not a big issue, so i can pull them from any third gen diff on any car and they will work then?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
.....The only axle shaft choices you have a 26 spline which was used up to 1989 and 28 spline which was used from 1990-1992. You can put 28 spline axles into an older car as long as you use the proper carrier for 28 splines. 1989 was a changeover year but the majority of the 1989 cars got 26 spline axles. Very few came with 28 spline axles. If you only need a 26 spline axle, any axle shaft from a 82-89 third gen will fit. Left and right axles are the same length in a third gen.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Yes it was answered above but you need to know whether it is a 9 bolt cover or a 10 bolt cover rear end. Axles will not interchange fron a 9 bolt to a 10 bolt or vice versa. The whole rear can be swapped though.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
