T5 fluid change
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
T5 fluid change
How many quarts of.fluid does the T5 hold? Im.changing the fluid after the clutch n flywheel replacement
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: T5 fluid change
just a little less than 3 qts. . would recommend full synthetic . good luck .
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: T5 fluid change
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Engine: 4++,350 & 305 CIs
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
Re: T5 fluid change
I love this site lol u guys are badass haha good looking guys, is their a manual for repair n maintence for the 2.8 3.1
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
