Help me ID this ring and pinion
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
OK guys. Thought this would be a quick Google search but I'm turning up nothing so here goes.
Popped the differential cover to change the fluid and I'm trying to ID this ring and pinion to check the size, ratio and see if this is a standard open carrier. The markings stamped on the ring gear read:
GM-14085338-13:42--7-5/8---3-84-1
Be back with the pinion casting in a sec...
Car: 1985 Z28
Re: Help me ID this ring and pinion
I'm having a hard time making out the pinion, but it looks like it reads:
14085343-13-42-GM
14085343-13-42-GM
Car: 1985 Z28
Pic of carrier:
42 / 13 = 3.2307692307692307692... most of us would call that 3.23.
Can't really see what's inside the carrier since the window is turned away from the camera, but it looks like probably yerbasic stock open diff.
LT1Formula
Oct 8, 2015 08:34 PM
