What automatic tranny does the LB8 V6 have?
Old Aug 24, 2011 | 02:29 PM
Balthazine's Avatar
Car: 1985 Firebird
Engine: LB8 2.8L V6
Transmission: Automatic
I have a 1985 Firebird, base model, with the LB8 2.8L V6 in it. Automatic transmission. I've been searching and haven't found a definite answer as to what the tranny is in my car. I've heard it's either the TH-700R4, or the TH-200R4. So which is it?
Also, is the shifting electronically cylinder powered or is there a linkage cable connected to a link arm that connects it to the shifter.
And, if you could tell me if it has the chevy bolt on pattern or the BOP bolt on pattern, that would be great.
Old Aug 24, 2011 | 02:57 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: What automatic tranny does the LB8 V6 have?
700r4, its not electric, the newer version redesignated(but internally similar, and replaced the 700r4 in the applications it was used in) is designated as 4l60-e, name varying a bit with application, first # refers to gears, the 2nd digit is L for longitudinal or T for transverse(refers to orientation of the trans/engine in the car) then the next 2 are a rating for how much torque it can take, and the E on the end tells you its electronic.
As for the 700r4 it shifts via governor, if you have ever seen a bike with an automatic(yes they do exist) they have this spinning governor type device on the rear cog set, that spins, and centripetal force pulls it out, or lets it go in, 700r4 uses something similar so far as I know and understand. The TV cable doesn't directly control shift points, it controls line pressure mainly. Idk what BOP bolt pattern is, but for the v6 3rd gens it has a 60* bellhousing/bolt pattern, the v8s have a 90* bellhousing.
Old Aug 24, 2011 | 03:27 PM
Balthazine's Avatar
Car: 1985 Firebird
Engine: LB8 2.8L V6
Alright thanks a lot. And this page will tell you what the BOP (Buick Olds Pontiac) bolt on design looks like. http://tech.oldsgmail.com/trans_bp.php
I just ask because if I ever want to do an engine swap I want to know what kind of engine I'll need so I won't have to do a tranny swap too.
Old Aug 24, 2011 | 03:40 PM
Engine: 3.8, 3.4
As far as engines that will bolt to the 700r4, chevy 2.8, 3.1, 3.4, both fwd and rwd engines will bolt to the trans. There is also the 3100, 3400, 3500, and the 3900 MIGHT, but idk if it does or not, same for that new 3.6 LLT, it MIGHT, but probably not. You're pretty much limited to the gm 60/6 line of engines as far as directly bolting to the trans, and the FWD ones require motor mount fabrication.
Old Aug 24, 2011 | 04:28 PM
Balthazine's Avatar
Car: 1985 Firebird
Engine: LB8 2.8L V6
Alright, thank you for all the help.
Old Aug 24, 2011 | 04:49 PM
Balthazine's Avatar
Car: 1985 Firebird
Engine: LB8 2.8L V6
Also one more thing. The other day when I tried to shift into reverse my shifter was stuck in park, and when I got it out of park, it just glided past all the other gears. It clicked but did not lock into place, nor did the tranny shift gears. It feels like the shifter isn't even connected to the tranny. Any idea what might be wrong with it? If it's the tranny itself or what?
Haven't had a chance to look under it yet, but the car is stuck in park, and won't shift or change gears when I move the shifter, just glides right past the other positions, just making a clicking noise.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
