Clutch alignment tool
Old Aug 28, 2011 | 04:43 PM
85_ZED28's Avatar
Car: '85 Z28
Hey guys,
Does anyone know if this clutch alignment tool will work for a stock T5 clutch? Link below:
http://www.princessauto.com/workshop...-aligning-tool
Old Aug 28, 2011 | 04:57 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Clutch alignment tool
while that tool will more likely than not work , why ? every clutch & pressure plate i have changed in several years came with a plastic alignment tool . good luck .
Old Aug 28, 2011 | 05:17 PM
85_ZED28's Avatar
Car: '85 Z28
I'm not replacing the clutch, just swapping it from one engine to another so I don't have an alignment tool.
Old Aug 28, 2011 | 05:25 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
1 & 1/8" ... yeah it should work.
A used input shaft is best.
I've only used one like you linked once.
The plastic ones work fine as long as you wobble it up and down and set it slightly upwards from centre (maybe 5/8 of total travel) before tightening the bolts.
A nearby shoppe is bound to have a junk input or plastic tool they'll sell you in case that one's not in stock.
Old Aug 28, 2011 | 07:04 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You don't really "need" to use a tool to do it. just have to center the center of the disk over the pilot bearing.
Easy!
Old Aug 28, 2011 | 09:41 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
That's right, you can do it by eye. But I would buy this plastic one. It's cheap as dirt and it works great:
http://www.dormanproducts.com/p-1752...ignment%20Tool
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
