Contact Pattern
Old Sep 10, 2011 | 01:17 PM
masteller's Avatar
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
Contact Pattern
Was wondering if someone can point me in the right direction with this contact pattern? Im new to doing ring and pinions. These are used 3.42 gears out of a 98 camaro. Back lash is at .10 right now.
http://s220.photobucket.com/albums/d...rent=gear2.jpg
http://s220.photobucket.com/albums/d...rent=gear1.jpg
Old Sep 10, 2011 | 05:17 PM
masteller's Avatar
Car: 1991 RS
Engine: 355 TPI
Transmission: t-5
Re: Contact Pattern
Anyone?
Old Sep 10, 2011 | 06:11 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: Contact Pattern
Used gears are a little harder to work with. The gears I used were used and they have a slight whine when coasting at a certain RPM. I couldn't get a perfect pattern on them so I did my best.
http://www.stevesnovasite.com/forums...ad.php?t=49839
Part of the way down the page is a good diagram on tooth patterns.
Old Sep 10, 2011 | 07:01 PM
Car: 1990 Camaro RS
Re: Contact Pattern
The drive side has heel contact, and the coast side has more toe than it should. Try and get the coast side closer to center and the drive side closer to the toe.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
indygene
Sep 26, 2015 11:21 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
dimented24x7
Sep 17, 2015 06:58 AM
